Which would you choose?
Enermax Whisper II EG465P-VE FMA 460W
http://www.newegg.com/Product/Product.asp?Item=N82E16817103464
FSP Group (Fortron Source) AX450-PN 450W
http://www.newegg.com/Product/Product.asp?Item=N82E16817104954
I've posted earlier about building a large disk array, but until I can build a dedicated file server, I need a new PSU for the machine that is tiding me over. It's basically a low-end socket-939 based machine, but currently has five high-capacity hard drives in it. And there's a possibility that I may add up to two more.
The Enermax has a single 12V rail with 33A, but it costs a full 50% more than the FSP with dual 12V@18A rails. I'd really like to save the extra money if it wouldn't be such a bad idea.
If you were buying a PSU for a system with a lot of disks in it on a tight budget, which would you choose?
