PSU for Asus P6T SE?
Marc Ross Miller
Hi.
I'll be buying an Asus P6T SE motherboard. My pc currently has a Antec 550 PSU. Do I need at least 600 Watts?
Thanks again.
Which Antec 550W PSU do you have and what are the rest of the components you'll be using?
depending lots of others stuff.. like sli/crossfire cards.. how many hdds cpu dvd and other stuff.. use the online calculator by filling out your components.
I currently have a 550 Watt Antec® TRUE POWER 2.0 Quiet Power Supply with 120mm Smart Fan (SLI Certified by NVIDIA). I'll be buying an Intel i-920 or i950 processor with 6GB DDR3 memory.
Someone on this list told me that the Asus P6T SE requires a PSU of 600 watts. I've looked on Asus' website but I can't find this requirement (although I may be there I may have just missed it).
We don't use sli/crossfire cards. Currenlty, I'm using a an NVIDIA GeForce 8800 GTS card.
I'm not committed to using the Asus P6T SE. Also considering other boards but I'm not sure which one yet.
Thanks again.
The issue is not the motherboard itself but the other components connected to it. The motherboard requires fairly little power on its own. Technically that PSU has enough power for your components. However, I do not recommend that you use it, because the Antec Truepower and Truepower II series had an issue where cheap capacitors were used that were very sensitive to heat-related failure, and the fan control was set aggressively so that it was generally not running fast enough to cool down the components adequately. This led to many early capacitor failures on these units, which can lead to damage of other components. Since you'll be using a fairly high-end system, you could be accelerating the death of the PSU, which would obviously not be a good thing. Therefore, I recommend that you replace it with a newer power supply, which would also have other advantages such as active PFC and significantly better efficiency.
A quality 500-550W unit, such as the Antec earthwatts 500W will be enough for that system.
Also, save $300 by going with the i7 920 instead of the i7 950 since the 920 can be overclocked to past 950 speeds.
