PSU for Antec P180
spicey
I'm looking to upgrade my PSU. Can anyone recommend a good PSU for the aforementioned case.
I need the power connector (both 24pin and 4 pin connector) to go all the way to the top right of the motherboard near the 120mm extract fan at the rear and the 120mm extract fan at the top.
Preferably the PSU should be around 500 - 600 watts with at least a combined rating of 28 amps on the 12v rails. Any ideas? Cheers
Last I checked, the HX520 or HX620 should fit the bill just fine. The length is ~20-22inches.
EDIT: iirc either clubit.com or buy.com have the lowest prices on those power supplies.
I used an Antec NeoHE for a while that I liked. I now have a Seasonic M12 also also reached to the top of my P180.
my mate just bort corsair hx620 and the wires fit fine and its a nice psu i might have to pic one up to
ThermalTake 650W cable management = the suck for 12v Motherboard connector.
