PSU for an i5 build
recursive
I currently have a CORSAIR 550W PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004
I'm planning on upgrading within a few weeks to:
Core i5 750: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115215
MSI P55-GD65 LGA 1156 Intel P55 ATX Intel Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813130239
4GB G Skill ram: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231277
I'll also be reusing my 8800GTS, 320GB HDD, and optical drive in this new build.
Would the 550W PSU be able to power all those components or would i need to upgrade it also? And if it does, would i run into any issues later on if I do decide to upgrade my video card to something more current?
The VX550 is more than enough for your rig, and will be plenty for any next-gen single-GPU video card as well (and possibly even dual-GPU cards depending on their power requirements).
I'm running an Antec Neo HE550 in my i7 rig and it is running perfectly stable.
So if I were to go down to Frys right now and pick up a shiny new HD5870, I'd be perfectly fine?
