Hello, I'm new here, so I apologize if this was touched upon in the past.
This summer I'm building a storage server that will contain 18 storage disks and 1 OS disk. I am looking for a PSU that will be able to power these drives in addition to an AMD 64 X2 Brisbane at stock clocks, with 4 SATA controllers in the PCI slots. I would like to spend $200 or less. I have no preference as to whether I should use a single PSU, or use one for the system and one for the HDDs. Combined cost should still be around $200.
The two options I've entertained so far:
1.) Dual PSUs: The FSP Green PS FSP300-60GLN ATX2.0 300W for the system + The SeaSonic M12 SS-600HM ATX12V / EPS12V 600W for the drives
2.) Single PSU: The PC Power & Cooling Silencer 750 Quad (Black) EPS12V 750W for the entire thing
I'm fairly certain I have enough wattage for the system, the only thing I'm unsure about is the amperage. Does 18A on quad 12V rails mean the same thing as 72A on a single 12V rail? I read through a bit of the info in the stickies, and I know I have enough amperage with either option to handle all of the drives spinning up at once (my controllers do not support staggered spinup; they are quite cheap). Also, both options use PSUs that have decent efficiency numbers, which I value. Active PFC is important.
To sum it up: Lots of hard drives need power. I have $200 to spend. I care about efficiency. Single PSU? Dual PSU? Amps distributed over rails, or all on one? Taking your thoughts. Thanks.
