Originally posted by reflex33
Remember that your going to have to run that on a different plug, 12A is a lot and you may blow the 15A breakers in most homes (that means no lanning with that thing!)
Originally posted by zer0signal667
It doesn't take 12 amps of AC current to transform into 12 amps of DC current, you can't make a direct translation like that. For example, a PC power supply may be able to supply upwards of 40A to the 5V line, or 20some amps to the 12V line. 120VAC drawing 15A is really quite alot, that's 1800Watts of powerCompare to the 288 (24Vx12A) that the peltier needs... and it doesn't seem so much.
