I have an Antec smartpower 350 PSU with a fan that appears to be going bad...making vibration sounds...getting louder by the week etc. What fan would be a good replacement? It appears to be an 80mm Antec brand fan. I'm looking for adequate cooling with it also being very quiet. This PC (my wife's) will soon be moving into the den area near my living room. The last thing I need is a constant whining whirrrrrrrrrr sound coming from the case.
BTW, it is the fan that faces downwards inside the case not the rear exhaust fan if that makes any difference. I also understand that I may have to exchange the fan connectors to get it properly connected inside the PSU.
Any recommendations? The PSU is still running strong it's just the fan that is dying.
