Mar 12, 2006 #1 K Kain Limp Gawd Joined Jun 13, 2004 Messages 279 Does anyone have a PC-73SLB and PCP&C 510 Deluxe? If so, are the cables on the PSU long enough?
Mar 13, 2006 #2 [Spectre] I Will Find You Joined Aug 29, 2004 Messages 24,889 When you order the PSU PC Power and Cooling will make a custom length wiring harness for you.
Mar 13, 2006 #3 K Kain Limp Gawd Joined Jun 13, 2004 Messages 279 Already bought the supply from Perfomance PCs.
Mar 14, 2006 #4 K Kain Limp Gawd Joined Jun 13, 2004 Messages 279 Anyone? A custom PCP&C is out of the question right now. I'm referring to a stock unit.
Mar 14, 2006 #5 [Spectre] I Will Find You Joined Aug 29, 2004 Messages 24,889 Kain said: Anyone? Click to expand... Did you measure to see how long of wires you will need?
