PS4 HDD, SSHD and SSD Performance Testing
HardOCP News
[H] News
PC Perspective has an interesting article posted today that shows off the performance benefits of a PS4 hard drive swap using an SSHD and an SSD.
The most dramatic change was seen in the AC IV testing, where the drop from HDD to SSHD was 19% while the drop from HDD to SSD was an impressive 32%. Clearly the SSD is the best option but we saw some interesting results in the SSHD benchmarks.
Hard drive is pretty easy to get at but but super easy. PS4 wont have external storage support and games are going to be fully installed on hard drive, good luck there sony...
Ummmm Xbox One has mandatory hdd installs and you need a proprietary Microsoft HDD. At least Sony lets the end user upgrade with any 2.5" sata hdd. I believe it's caused by slow bluray read speeds. Also your first sentence makes no sense...
Personally, I want to give the 1TB SSHD a shot. Not too expensive and I can reuse the original 500GB 5200rpm drive for something else.
I keep seeing these type of reviews of sorts but I have yet to see someone actually say that the ps4 actually supports trim.
first sentence is a vague attempt at describing how to get to the hard drive, it was easier to get a ps3 hard drive then a ps4 one.
Microsoft also support external storage, ps4 will not. Both have mandatory game installs. Guess how this effects you if you have a ton of games? Microsoft you just need to plug in 1 2 externals over the usb 3.0 ports, PS4? swap hdd.
Hard drive space utilization on PS4 is overblown if using physical discs. It's only a concern if you're downloading full digital installs. I feel less of an urgency to upgrade to a larger HD now that I own the actual PS4 product and understand it more.
All games and downloads have to be installed regardless if you bought it retail or own the disk.
The speed increase vs Hard drive capacity decrease and no TRIM supports makes it seem it's not worth going SSD at this time in the PS4.
If I were swapping HD's I'd go for the older 7200 RPM Seagate Momentus XT 750GB drive with 8GB of SLC flash.
It's considerably faster than the 1GB 5400 SSHD that Seagate replaced it with.
Unfortunately, it's getting a bit hard to find, and as a result is a bit pricey.
http://www.amazon.com/gp/product/B00691WMJG
Id say understanding the PS4 is what drives me for more storage. The Remote play feature is at its best with digital titles. Otherwise you can only remote play the title thats actually in the PS4 at the time. May not apply/be a concern to everyone, but it is a valid consideration when making the purchase
Not sure why you said that, if you have the PS4, you know that ALL games have to be installed to the hard drive.
So, slow as hell even with a decent SSD?
Well it's starting from hitting play the game till it starting the game. So you have to go though like 20 not skip-able logos, for EA THQ bleh blah blah just like you can have windows 8 load out of hibernation fast but still go though a stupid load bios boot.
I guess that makes sense. They should include loading savegames as well.
loading save games and in game load times are probably the more important numbers than cold boots with consoles. Not that a matter of seconds really impacts much (although i do like that my rig boots in less than 10 seconds :D
I was at a buddy's house this weekend and played some GTAV. Load times for saves were in the ~2 minute range. I don't know how people tolerate that crap.
The same as how we used to tolerate 5-10 second load times between levels in Half-Life a decade and change ago. They have nothing better to compare it to and have no options to improve it as of current. Looking back now, I agree, I have no idea how I put up with all of the loading of the pre-SSD world. But, I did nonetheless. That said, I can't imagine waiting two minutes for loads today.
Is the no Trim support confirmed?
Listen to what you are saying.... tolerating a 10 second load vs. 2 minutes. And it was as unacceptable back then to have crazy load times. I forgot the game but it came out around HL2 and it was mocked incessantly for it's several minute load times that take you out of the game and it's huge (100MB+) save files.
So so performance increase IMO.
This kind of performance makes it hard to justify a SSD upgrade considering the cost involved.
This just proves that console owners are like monkeys clinging to parcels of crumbs being thrown their way on the tech front.
That would be Sin
As was pointed out in other places,
There was no test of a 7200 RPM HD. I loaded one in my PS4, and my load times are just under the SSD's speeds of this test. I would urge the guy who did it to obtain a fast 7200 drive, with a large cache and compare that.
This just in, next gen console has same hard drive found in 15 year old Packard Bell.
I would rather stab myself in the eye than put a 5400 RPM drive in a gaming oriented device.
Yea, I am really unsure of why they went for these 5400 drives other than to save a few dollars. They must have gotten them at quite a discount.
The lower RPM results in lower heat and wear on the bearings, and may also be quieter. Choosing a particular RPM is a compromise between speed and reliability (at a given price).
Sony made this decision for the people who want to just plug it in and use it, so they picked the most reliable (rather than fastest) part for the price. The majority of people who are likely to care about the speed of the HDD are the same people who will probably upgrade anyway, and Sony catered to them by making the drive non-proprietary.
