PS3 HDMI cable at WalMart
culthuu
Don't know if this qualifies as a hot deal but it seemed pretty good to me. Was in a WalMart store in Melbourne Florida and in the TV section I found a six foot HDMI cable for the PS3 for $15. It was half the price of the cheapest one they had. I'm no expert on HDMI and I don't have a PS3 but I bought it anyway to try on HTPC. It works as far as that goes. It's made by a company called METOP and comes in a black box that just says HDMI. It's approx six feet long and has gold connectors. The small instruction and information sheet in the box says it's V1.3. The cable itself is in a nylon sheath like you find on power supply cables. It seems to be pretty well constructed but like I said I'm no expert.
HMDI cable at amazon for $2 or monoprice for $3. It's a digital connection so it really makes no sense to buy something "special".
99.9% of all HDMI cables are v1.3 compliant. If the cable was made in the past 2-3 years the cable will work fine. It's a marketing ploy. Companies say its v1.3 capable just to make u think its better than other hdmi cables. Monoprice cables are top of the line and have amazing prices and ultra fast shipping. Monoprice FTW!
That isn't a good logic to go by. For cables under 10 feet, cheap is fine. Anything over that and you'll want a better quality cable like the high end priced monoprice cables, bluejean cables, or something else high quality. But, monster is far too overpriced. If you go for a cheap cable on longer runs, you can face digital dropout, bad color convergence, signal attenuation, etc. We just had a huge battle in the HTPC sub-forum if you want some more info about it.
good price for a retail store....that cable is normally $40 --- just say it yesterday at my wal-mart for $40 and laughed because I know how cheap monoprice is.
Check out monoprice.com for better prices and cheap shipping.
