Run.Dos.Run
- Jun 16, 2004
I have seen lots of mods using these, and i was wondering if any one had some info on how to take one apart and such to get ready for insatallation, thanx.
FLECOM said:got two of them when they went clearance at my compussr... got two of them for like $40![]()
where can i get a cheap and simple composite video camera?tom61 said:USB isn't going to work like that. For reasons too long to put here.
You'll need a composite video camera if you want to hook it to a PS1 LCD.
n64man120 said:My card only has 1 vga on it, so I guess I would need to buy a cheap PCI videocard to run it. My question is how do you get the PSone display plugged into the VGA port on the card? I dont get the whole middle step and if any extra hardware is needed.
Techx said:if you actually looked at the link i posted you'd see exactly how to do it.
The guys who have done this mod recommend you get a PCI Matrox Mystique off ebay (they are like 5-10$ us) since they support csync, even newer Geforce cards may not support csync and images wont display properly on the screen without it
n64man120 said:Yea I did read that article about 4 times, but theres a few things i'm unsure of. What is he refering to when he says CCFL? I thought that was a cold cathode light which would go inside a system however i doubt thats what he means. Also after reading it carefully I still dont get how you rig it up to the videocard. Do you get a VGA cable and hack one end and solder the vga cables wires together with the cables from the display?
THnx
n64man120 said:So would it be correct to say that besides the VGA cable, absolutly nothing but the PSOne must be purchased for this mod?
do you need drivers or can is it like plug and play?FLECOM said:believe it or not its in the video lcd faq
but here are some links for u
http://www.mp3car.com/vbulletin/showthread.php?s=&threadid=13313
http://starfox.ucc.asn.au/carcomp/serio_lcd.htm
i have a pair of these that i VGA modded, works quite well actually...
hey buddy, wanna make a quick buck?... name a price, lolTechx said:Mine is STILL in one piece, collecting dust, waiting for me to get motivated to mod it![]()
how do i hook up a composite video camera to a ps1 lcd?... i ll worry about where i ll get one latertom61 said:USB isn't going to work like that. For reasons too long to put here.
wayne said:how do i hook up a composite video camera to a ps1 lcd?... i ll worry about where i ll get one later
any guides?, if possible... i dont know exactly what to google for
whats NTSC and PAL ones?
i tried to do this mod and it got really messewd up and didnt work with the guides to convert it to a vga
otherwise this was a really easy mod to do with the wire.
