PS with short cables available?
tombew
Has anyone seen cables available for any modular PS other than the Silverstone 500 (or is it 550)?
Silverstone sells the short cable kit separately, so you can use it with (presumably) any modular Silverstone PSU.
Similar to what Zap suggested, the PP05 short cable set can be used with a variety of different Silverstone strider PSUs. A search for that part on their website includes this list of compatible PSUs:
SST-ST60F (after V5.0)
SST-ST70F
SST-ST1000
SST-ST1000-NV
SST-ST1200
SST-ST1500
SST-ST50F-P
SST-ST60F-P
SST-ST75F-P
SST-ST85F-P
SST-ST1000-P
SST-ST75F-G
SST-ST85F-G
SST-ST1000-G
SST-ST1200-G
Thanks for the replies, Zap and DesertCat.
So Silverstone is the only one?
You could always get a crimp tool, a pin extractor and some crimp pins and shorten them yourself.
