Hello everyone,
Im in the process of putting together of a system. Only one real question that I cant seem to find a solid answer to. Below are the main specs of the computer (go ahead and comment on what you think). Im still questioning the vid cards. I know I want to run 285 SLI but not sure on which one to go with. The main question is will the power supply that I have picked be enough. I plan on OCing the processor to around 3.5ish, along with ram most likely. The only other item that I dont have included is a separate hdd setup, running (x4) 1/1.5TB hdds, in a separate case, but thats a different question in itself. So mainly will my 750w be able to handle the setup I selected?
EVGA 141-BL-E757
Intel Core i7 920
(x2) MSI N285GTX SuperPipe OC GeForce GTX 285
Mushkin 6GB (3 x 2GB) 240-Pin DDR3 SDRAM 1600
(x2) Seagate Barracuda 7200 1TB
Thermaltake W0116RU 750W
Link:http://www.newegg.com/Product/Product.aspx?Item=N82E16817153038
Thanks
EVGA 141-BL-E757
Intel Core i7 920
Thanks
