PS concern
Harbinger
Hello been away from the computer scene for awhile. I just put together a system(see sig) and I have a concern with the powersupply. The nvidia software is reporting under voltage, the HT in red and memory in yellow. Is this software accurate? Is this powersupply ok? I was worried cause it had no 8pin 12v connector but the MB manual said you can still use the 6pin. The system seems to be running great with no problems noted thus far.
