A quick and hopefully easy question....
I recently got a Nspire 550W PS for a full tower case (ATX). When I did a test fit to the case though I noticed that while the back of the PS was correctly oriented to the opening in the back of the tower, the wiring was coming out the side of the PS case furthest from where the mobo is mounted in the tower case.
Someone correct me, but isn't the wiring ALWAYS supposed to come out of the side of the PS case closest to where the mobo is? Is it possible that the PS was not correctly assembled, or the PS opening in the tower case not correctly oriented?
Thanks!
Edit - the PS is mounted horizonally in the tower case, btw.
Thanks!
