PS/2 Blue Neon Lights
DRJ1014
I have the PS/2 Light up Neon Keyboard. I just got the newest one that is not avaliable in stores yet. You can only get it through a private dealer. I dont have a picture of it buts its like the olders one xcept of the expansion buttons (shutdown, Restart, Games). My Question is if the light(s) burn out how would i replace them?
well, if you have what i think you have, it doesn't have lights. It may have leds, which last a LONG time, but more likely it has EL wire, which also lasts a long time. If its LED's and they burn out and you have to replace them, it'll be a bitch and you'll have to sodder them on. If its el wire, youlll also probably have to sodder but not uch.
Its probably the EL wire, and i wouldn't worry about a thing tike that.
