PRPNet Help
Tornlogic
I don't know if anyone here has any experience with the PRPNet windows client, but I figured I would ask here first. I have searched around these threads, but no dice. Here is my problem:
I ran the install bat file for my CPU, then I changed all the variables in the ini file. Next I ran the udpate bat file, then the start bat file. When I run the start bat file i get a number of windows errors saying "Code execution cannot proceed because it cannot find MSVCP100.dll, OpenCL.dll and VCOMP100.dll. In the ini file I chose the 64 bit executable. The only section I'm unsure of is this one, and these are my current settings:
// This is the name of the executable used for Wieferich and Wall-Sun-Sun searches.
// Available ONLY to 64bit OS. Uncomment if you have 64bit OS.
// If you have an OpenCL-capable GPU, uncomment 'wwwwcl'
wwwwexe=wwww.exe
wwwwexe=wwwwcl.exe
wwwwexe=wwwwcl64.exe
I'm unsure of what to do to remedy this issue.
Thanks
