protecting the core
daven1986
I have a zalman 9500 HSF and im going to take the IHS off my opteron, however my computer is a tower therefore the 9500 is horizontal, i know this will cause it to rock on my core so i would like to put some foam on the sides to stop this occurring. so here are my questions:
1) any special type of foam or tape, or will any do?
2) how thick is the core, and therefore how thick should i make the pads?
thanks
daven
I left my micrometer in my other pants, so I didn't measure the thickness of the core when I had mine exposed. The ridge around the outside of the heatspreader is about 1/16" thick, and there was some thermal "paste" on the core, though it was a solid when I opened it up.
I would just make sure whatever you use will compress down to 1/16" or less, or else you may end up holding the heatsink off the core and then it'll poof.
