Props for sig changes
Status
Not open for further replies.
drizzt81
I like the changes (sigs are smaller...) a lot. Major props to the person coming up with that idea. thanks :)
I thought something was screwed with my browser at first.
It's fine though. It will just take time to get used to it.
I wish the user info was all in a line going across, then the post could be under it, so it's not so... badly laid out?
I have sigs turned off, and the layout is now kinda goofy, with the first paragraph hanging. The posts swim because the user block varies in width (depending on the length of the user name).
I totally agree
I thought something was fucked up
I guess I will get used to it
Sigs look ok.
If this change is permanent, what needs to be done is what Borg suggested...
One of the things that greatly improves design layout is when things line up vertically.
also, thanks for listening to the users and putting up with us :)
Is it supposed to be like this:
Tried it in Firefox and IE, both look like that (the text wraps around then under the username). Just doesn't seem....natural. Though I do like the smaller and lighter sig font...whew, been needing that for a long time.
Give it a week to grow on you, then if it still bothers you, please come back and whine then.
QFT
I don't like how stuff ends up under the user name, it never looks cleans. Its need to have a better table alignment.
yeah, at least line things up properly
the uneven lines and out of place box looks weird
not like we have any say...
Status
