Proposed motherboard layout
The Oatman
With watercooling and SSDs being increasingly commonplace, one of the major limitations in case dimensions right now for enthusiast rigs is the width of a full size video card. With a motherboard that has integrated sound, NICs, etc, the video card is often the only expansion card needed for a basic, though powerful, gaming machine.
What if a Micro (or smaller) ATX motherboard was available which allowed for a parallel mount of the PCI-E expansion card. It would be shortened with only a single traditional perpendicular mount PCI-E 1x slot but the slot meant for the graphics card would be at the " bottom" of the motherboard, sticking outward. This would require a new type of case but when combined with clever watercooling and compact (or external) power supplies, it could bring self built, overclockable enthusiast rigs into iMac territory minimalism.
Thoughts? Would this violate some law of motherboard design that I am not aware of? Even if there is not a market I am curious if it is possible.
I don't really see it being feasible. For one, the card would be facing the motherboard tray, so that's going to be difficult to get airflow, or route water lines to the block... etc.
Another, is with a m-ATX board there's 4 slots. That leaves three slots in a typical full-ATX case. The card height is a lot taller than the width of those three slots. So the cases would have to be made bigger.
And if you needed that arrangment, they make adapters to change the orientation of the slot. So grab an ITX board, one of those adapters, and you're set.
