Proposed build, add or remove anything?
dgsg
CPU: Intel Core 2 Duo E6600 2.40GHz 4MB L2 Cache
CPU Cooling Fan: ZALMAN CNPS7000B-ALCU 92mm 2 Ball
Mother Board: Intel D975XBX2
Memory: 2GB Corsair TwinX 6400C4
Video Card: nVidia GeForce 8800GTS 320MB PCIE
Power Supply: Silverstone Strider ST60F 600 watt
HD #1: Western Digital 250GB 16MB Cache SATA 2
HD #2: Western Digital 160GB 8MB Cache SATA 2
Optical Drive: Lite-On 18X Dual Layer DVD+-RW
Case: Silverstone TJo4
if only everybody could pick out as good of parts as you did.
Still, I thought the Seagate 7200.10 drives with perpendicular recording are the fastest.
unless you already have them, or some specific reason to use 2, jump to a 7200.10 400GiB drive.
Personally Id go with a P5N or DS3 for the board. But you might have a different need than myself.
What are you using this rig for?
I agree, since you don't need crossfire, go with a P5B-E or DS3 instead. go with a better cooler than the 7000... go for the 9500 or 9700 if you want to stick with zalman. if not, the tuniq tower is good, as well as the scythe ninja or infinity.
definately go with a faster hdd. the 7200.10 320gb is significantly faster than the 250gb WD KS drive. I havent tried the 320gb KS drive tho...
Word processing, web browsing and Tetris.
and light gaming and digital photo processing and ProShowGold slide shows. May wait and see if the C2D chips drop in price in April. May also change to this MB;
http://www.newegg.com/Product/Product.asp?Item=N82E16813131071
you picked great components, i wouldn't change anything. i'm running the same CPU/MB combo too.
I've ordered almost an identical build here thats coming in a few days
http://www.hardforum.com/showthread.php?t=1158929
The only thing different on mine is the case and PSU.
You may want to consider the Corsair 520HX or 620HX PSU.
there rated very highly.
I don't see any issues with your setup, go for it!
