Proper way to install PhysX drivers?
newls1
so what is the proper way to install the physx drivers? The base Nvidia GPU driver already installs the "older" version. Once the GPU driver is finished installing, can I just install these newer physx drivers, or do I need to un-install the physx drivers that just got installed from the gpu driver, then install these newer ones?
I don't think it matters if you uninstall the old ones first or install over. I guess it would be safer to uninstall the old ones first. Just treat them like you would your other drivers, there is nothing special about it.
