Apologenetic said:Actually S-Video os higher quality than Component but the best is the R Pr Ph... i think that's what they're called... The Red Green and Blue High Def plugs... get a DVI to RGB plug that can plug into your DVI port and the HDTV RGB plugs int eh back of your TV
Bumrush said:What about sound? Do I need to bring my computer speakers as well, or are there adapters that can be used to connect my Audigy 2 to my sorround sound setup? Thanks
