Both would work; it's not like one is right and one is wrong.
The optimal configuration depends on your particular requirements - how much capacity, performance, redundancy you need. If you can explain a bit more about the context then we can make recommendations based on that.
I'm running something similar. I'd suggest plex/nzbget/nzbdrone though.Well, the storage is mostly intended for serving media to my HTPC,
and running Plex/SABNzbd/Sickbeard for media aggregation.
Yes there is a difference. Any RAIDz1 option will only have single parity, RAIDz2 has double, so you can lose 2 disks before data loss. With 2x RAIDz1 vdevs you can technically lose 2 disks before data loss,but thats a misleading data point, as you can still only lose 1 disks per vdev before data loss.Is there a redundancy difference between a pool of two RAIDZ1 vdevs vs. 1 Vdev of RAIDZ2 ?
so there is no redundancy risk in using 2xRAIDz1 vdevs?
Should I go this route or bite the bullet, purchase 3 additional drives
and just go for 8x3TB raidz2?
If 1 disk fails from either or both RAIDz1 vdev then you would have no data loss. If a 3rd disk fails on either vdev after that point then you would have data loss. However, keep in mind if 2 disks fail on either vdev you would have data loss.
I don't think there are plugins for nzbget/nzbdrone, but nzbget is in ports, which is easy to install.
