Proper PCIe bus speed (in BIOS) for 8800 GTX...
OsageCowboy
should the PCIe bus be set to 100 mHz? is this the default value for PCIe and what the 8800 GTX uses?
100Mhz is the default speed,but some of us oc a little.I have mine set at 110 :) It hardly
makes any difference though.
Running it at 110 just stresses the card more, it won't run any faster!
That's correct. The only reason to overclock the PCIe bus is if your OC isn't stable with it locked at 100. Or some other board-specific bugs that I won't get into.
