Forgive me if this would qualify as extreme cooling, if it belongs there feel free to move it.
So I was throwing some spare parts into a case the other day and had an idea: I've always wanted to play around with a TEC, plus everyone says they are a bad idea (challenge accepted!). I've tried googling to see if it has been done before and I couldn't find any info so maybe it's a dumb idea? Regardless, the parts are already ordered and on the way - no point in turning back now! I'm going to run a TEC through a PWM controller with a potentiometer on it as a way of directly controlling the rate of cooling, to fight condensation, plus the power will be fed through a relay so it'll only be cooling when the PC/PSU are powered and running. I'll be using a Scythe Mugen 3 on the hot side of the TEC (with at least one 120mm fan, possibly two in push/pull, we'll see), a 90w/138w max TEC, and a copper cold plate on a Phenom 9850BE/M2N32-SLI combo. From what I've read the temperature of the cold side of the TEC is directly effected by the amount of heat you can dissipate from the hot side; I figure the Mugen 3 will dissipate enough to match or beat the 125W TDP of the 9850BE at stock clocks with no problem, so if the TEC is PWM-controlled to throw even 200W of equivalent heat off the hot side, the cold side should be at least below ambient. The only thing I'm worried about is whether the TEC will hold up to a PWM pulsing the power - but if the concept works I might upgrade to a more powerful TEC/cooling combo. The whole thing is going to be well under $100 invested so if it fails miserably it was at least a fun project and I'll finally be able to say I got to play around with a TEC.
