Projekt Crazy BLOBZ...
[PROJEKT "CRAZY BLOBZ"] // ...A.Bistro
Hi all , happy to post here again :D
Pix clickable....
[Le setup]
Mobo: Asrock K8NF4G
CPU: AMD 64 3200+ socket 754
Ram: CRUCIAL Ballistix Tracer PC4000 2x1 giga
Vidéo: ATI X1600pro PCI-E
HDD: Barracuda 120 gigas
DVD RW SONY dw-Q520a - slim
The PSU will come soon, i'll use a shuttle one.
[Watercooling]
Pumpstation 1A-COOLING
Waterblock CPU: XX-Flow Innovatek
radiator: Bix
Fan: for the next up :)
Tubing: Innovatek orange fluo (thanks Osiris) ;)
The pumstation and the rad were in ghettho status :)
After a p12::fred00 sanding they looks better. They 'll be
black painted.
The waterblock need more sanding, he look good now.
The start object is the same than in my previous mod ("40")
mod "40"
The rack display VARTA, the box (next pic) is steady on the
bottom
I'm planning on making something different but in the same spirit.
This time the baby will be watercooled. Not an easy thing to do regarding
the mensurations of the box.
[size of the box]
height : 42 cm
width (top and bottom): 24 cm
width (middle) : 29 cm
depth : 15 cm (nearly a CD DRIVE)
[accesories..]
I will use all the mess i'll can find in my workshop..plexi, alu, and of
course mesh , under all her forms. :)
I've some leds in stock.
[tools]
Dremel multipro, drill, sander, jig-saw, arms, beers....
[Le principe...]
The pumpstation will be on a little tablet made from smoked brown plexi.
The plexi is a little damaged but it wont be really seen.
The pumpsation will stick out from the top of the box.
The radiator will be on the bottom with a fan over it, the airflow will be from the inside to
the outside.
The fact that the box is totally in mesh will help for the functioning......i hope.
Tablet for the pumpstation
I started very soon this morning, fortunatly i was wearing my warm blue sweat and my cool hornet...
Dremel cut on the top
and on the back
a senfu will be added on the front. The senfu will check the CPU temp
[For the feets...]
For the feets I've saw the 2 verticals tubes
Of course they wont stay like that :)
[The thing "idontknowthename" use for the brackets PCI..]
The "idontknowthename" has been retrieve from an old case
[For the DVD RW...]
I decided to run for a slim dvd rw
The little adaptator fixing is strengthened with double face
Cut for the dvd and lucky me .. the dvd thickness is just 2 lines on the mesh :D
fast fixing for testing.
[A first black painting, just to add some happyness and color...]
[Camouflage of the pumpstation]
This part made from mesh will be on the top of the case, on the pumpstation.
[Support for the tube IN]
Realise with smoked plexi and with "anotherIdontknowthename", used to avoid the door to hurt the
wall :) . Whith a led indahass, will look good.
[a bunch of deco]
[Blobz...]
hour H of the beginning of the Blobz's invasion......
They arrived from everywhere !!.. some of them have eyes ..
[End of episode 1]
thanks for reading or at least for scrolling, sorry for my still stange english.
rendez-vous for the next update...
something strange is happening.....
to be continued......
are you doing anything else for the blobs?
they look strange.
but other than that it looks pretty cool.
enough room for a ton of rads too.
Looks good so far.
The only thing is, the white blobs look really out of place as they are.
I would get a plastic cylindrical reservoir, mount it so that it shows through the front, and pump goo through it. :D
Awesome so far, can't wait to see what else transpires!
I'm a fan of your previous work! :D
Alonso!!!
Great to see you again!
I saw this mod linked off of the front page and was prepared to come in and defened your honor, thinking someone was passing this off as a 1st of it's kind!
http://forums.bit-tech.net/showthread.php?t=85389
Yeah, I loved what you did with "40", and followed it fondly! I saw this case and was like... "No way!"
But it is YOU! Yay!!!
Great to see you back on and cutting on another creation. I looks forward to where you take this one to!
Take care, and good luck!
:D :D :D
CRAZY BLOBZS part 2
Hi all
After weeks (monthes...) of busy life... I'm back with an update :D
For beginning this second part, it's necessary to announce some changes in the setup. Disc PATA of 120 GB was transformed into 320 GB SATA, the 3200+ (754) changed into a 3700+(939), the mobo always comes from Asrock but becomes a 939S56-M. The RAM arrived from CRUCIAL, 2x1 giga PC4000 Ballistix Tracer - (advertissement for sponso is not authorized on this forum so check my website for infos) . The power supply unit also arrived, it is a 300W used in the Shuttle xpc. These changes intervened recently and the first pics still contain the previous setup. We had been left in full invasion of blobzs, it would seem that they left as quickly as they arrived…. in short, exit the blobzs for the moment, we will see later if they reappear, I'm functioning (like usually) in improvisation's mode, nothing does not say that I'll wont re-examine them before the end.
:D This second part won't be very spectacular, now all the hardware is ready, and I considere this part as the real beginning. Next parts will be more fun.
We will attack directly in the fat via a small "how-to" on sleeving a fan, in fact a AKASA-AK-183 L2B. I particularly appreciate the silence (18dba), the good CFM (44,8), and the color amber of these fans.
To start, pull out the wires from the connector using a pointed ustensil on the small pins
of the connector, and draw back wires . I draw a small black spot with a pen on the connector on the side of the black wire, that allows me to
remember the order of wires to reassemble the connector correctly.
The black wire side of the black spot and the red wire always beside the black wire:).
Then to facilitate the passage of the three wires in the sleeve cover them
with painter's tape.(or other, but the painter's tape can be removed more
easily).Time to starts the introduction of the wires into the orange sleeve.
continue to thread almost until the end.
then it is necessary to have two smalls pieces of heatshrink, like those which I had much
problems to shoot. :)
then introduces a piece of heatshrink until the end by taking care to cover
the orange sleeve, and gently heats with a lighter without burning the
heatshrink (the better is being the heatgun).
If you take some pics, don't forget to clean your nails :), then use small girl
pink cutter to redress the small pins, as on the pics. Introduce the second
piece of heatshrink , plug the wires in the connector, listen to the 'clic', heats the heatshrink as
close as possible of the connector and voilà.
Be carefull with the order of the wires in the connector !!!
And you obtain a superb sleeved fan which will find his place beside the
painting 'hind in an underwood' which decorates your chimney.
"wotta l33t f4nz!"
Ok, let's continue with the box.
I've raised the case slightly by inserting two pieces of 8mm plexiglass between the box and the feets.
To ventilate the radiator I will go in push/pull. The fan in 'push' is an Aerocool Streamliner (14cm blue leds). It is fixed directly on the case. Those little silent-blocks are coming from the interior of a dead CD/rw, they will absorb the vibrations. (the new mother board being slightly larger, the attachment of the fan risk to be modified).
The fan in 'pull' is the sleeved Akasa.
Work on the new front by creating some pieces in white and transparent plexi.
The tubing run through 5 parts of transparent plexi, these 5 parts are fixed to the case with 2 screws. The parts in plexi white are bended by hand without heating. This last pic is not really important because the senfu will be replaced by a LCD blue Crystalfontz 4x20 like this one:
This white plexi part will be done twice, one on the top and the other on the bottom of the front and will be used to hold the new blue senfu. A little archaic bending system but work well :)
yeee, start to look at something (imo)
added black joint under the 2 white pexi pieces
This part will be used to cover the LCD on the front.
First test, the adjustement will come later. this is just to have an idea on how it will looks.
[The PSU]
The PSU will be on the back of the case, it'll be held by 4 L - 2 both sides and 1 under the PSU.
Before I can continue I need to paint the case. At the meantime I've painted the PSU
The PSU will be plugged by the bottom of the case, so I need to lenghten my psu wires. I was not really awake the day i cut :)
Soldering will be for the part 3.
And these 2 last pics for the road...
The third part promises to be animated, indeed I has just discover that the DVD does not fit any more because of new mother-board which is larger. The DVD will be installed in top on the meshed side. The parts in plexi on the front will be enlightened (UV, blue, orange). The side door will be attacked...
cya later
YAY! AN UPDATE! :D i loved projekt 40 and this is looking awesome too :D so this is a new battery rack right? those things are awesome :p what brand was it for? or was it just a generic rack that was used for batteries?
I usually do not post anything on these worklogs. I just watch silently from afar. But I had to drop a line of compliment here. This is looking very cool and unique. I love the Plexi work and the UV red/orange action. I have to give my vote on the "blobs" though. I would say leave them out, unless you can do something to make them fit in better. Also, I think I would leave out the blue 14cm fan on the radiator. Kinda sticks out like a sore thumb to me Just my opinion. I would slap on another Akasa Amber series, personally. I love those things! Great work, though. Keep it up!
thank you
I use this blue fan cause he had blue leds, if I can avoid soldering, wiring... but 2 Akasa could be cool too :cool:
BLOBZ PART 3
Hello
Yep an update.... :p
PSU
Let's start with the PSU
Problem, le 12v wire is too short
now the length is ok
All the wires are orange fluo sleeved
The radiator
After a good polish, the rad is black painted
protection tape
Camouflage of the back electriq mess
To hide the wires I've used a mesh, bended and black painted
The black rad will hide the rest.
The door
Ok, now the big part of this update, the lateral door.The door is made from a white plexi piece.
The 14cm fan moved
same shape cut in a metal sheet
and same shape cut in a ... snake skin
The snake skin is glued to the metal
This grill will go on the 14cm fan
Sorry mr pioneer ....
then U joint is added around.
The front
For the front I've used the same snake skin. The skin is hold on the main white plexi piece with double side tape
This plexi piece is used to hide the top of the shape
Orange plexi is added
To do: the bottom of the front, the feets, the inside, the DVD support...
Ok, see ya for the next update ...
lol that is awesome! I almost forgot about this project. :p The case looks like something out of a late 80's or early 90's scifi movie. haha. I like the white and orange plexi. Its hawt.
:eek:
Wow, just wow! I have never been so impressed with a case before. Excellent work man! I can't wait to see more!
That's freakin nuts.
Awesome project, it looks fantastic. Seems like a lot of work has been put into it.
