Projector Questions
Loki008
since i the display forum doesnt seem to be very active when it comes to Projector questions i figured i would give it a try here
I am looking to spend $1,000 - $1,400 on a projector, my main desire is native 16x9 support i have seem to have narrowed it down to the sanyo z2 or z3, most of the reviews i have read seem to say its an awesome projector except... and each one has a different except. are either of these going to be good quality displays or should i concider something else. basically what i have for an HD setup right now is a samsung 32" HDTV which i have been very happy with but is having problem fitting in my room where i am going to be setting it up because the way my room is layed out it would be almost in a walk way. basically the room is almost an L shape so i would have my bed against one wall with about 10-12" to the other wall, not sure the exact mesurment right now and i would have some shelving above my bed with the projector on the top shelf with the wall across the way covered with black felt projecting onto a home made screen, (plywood with silverscreen paint) and viewing would be from the bed
The Sanyo Z3 and Panasonic AE700 are in the same class and price range. The Panasonic tends to be more popular and is what I have. With the release of the Panasonic AE900 the price of the AE700 should be low if there are even any left.
Anyways, that's what I would recommend as I own it. Reviews and other info up at www.projectorcentral.com
The Z3/AE700 were basically small refreshes of the Z2/AE500. Both were SOLID proejctors that got better (I own the Z2). The Z4/AE900 are doing a much larger refresh this time by switching to the new D5 panels tha should provide a sizable improvement to contrast for LCD.
The Z3/AE700 will do you fine. Things that may shift your decision
1. What throw length do you need. I believe the Zx has a shorter throw and the AE is longer.
2. Lens shift....if you plan on ceiling mounting...this can make life so so so so much simplier.
3. Connectivity. Determine what inputs you need and compare the two.
I believe this time around people preferred the AE700 over the Z3 and last time the Z2 over the AE500. Both solid projectors. The differences were minimal but enough to cause people to shift one way or hte other.
Definately check out AVS....worth the time.
-tReP
basically i am looking for something that will do an 80-90" screen from 10-12' panasonic's website has a nice chart while sanyo's page seems kind of lacking on info on the z3. i think i am still going to lean towards the Z3 just becasue of the ability to blow out the LCD displays incase dust gets in there, and the 2 component inputs are a plus as well which means i have hook up the xbox and HDTV cable with component and if i decide to get a seperate DVD player ill just get one that upconverts and has an HDMI output
Just let the stereo receiver handle all the inputs. That's what I do. Satellite HD box, DVD Player and Xbox all go into the stereo and then one set of components go to the projector.
Yeah, but when you have an upressing DVD player that uses DVI-D...component is out =P
Blanket statements like that sometimes do not reflect the situation.
-tReP
Then DVI for the DVD player and component for everything else switched through a reciever. That's what I do with my projector and all of my components. switch it through the reciever or projector.
Ugh I'd just like to say if possible don't run video through your reciever unless you have a really damn nice reciever... all you do is muck up the signal and at 110"'s or whatever you can notice the difference... If you can go direct from source to output I would highly recommend it. Check it out for yourself first though, maybe you won't notice :rolleyes:
with most projectors, it is a bitch to run all those cables to it. mine is ceiling mounted and the work it would take to run multiple cable, forget it. I just convert everything to VGA and run one VGA cable
Well if you take the time to run one cable it would'nt take anymore to run them all together. I was lucky in that my house was being built. So I had them but a 2" flex tube from the reciever location to the projector so I could run whatever cables I wanted to. Right now it's just component but at some point when HDMI cable prices come down I will do that.
spectrumbx said:
Go with the Infocus 4805. http://www.infocushome.com/amer/eng/products/screenplay/sp4805.asp
I got mine for around $1000 after tax and shipping from TigerDirect. But there currently is a $100 rebate on it.
It is not a very bright projector, so you will need a controlled environment (all blinds closed during the day).
$1000 could get him a high definition projector instead ;)
The Sanyo PLV-Z2: http://froogle.google.com/froogle?q=sanyo+z2&btnG=Search+Froogle&scoring=p&sa=N&start=60
1280 x 720p
I said it was a pain, not that it takes a long time. how do you have yours run up the wall? to do it "right", you would route out a channel and runt he cable int he wall, then remud the wall and paint. the cables shouldn't be seen. at least, that's my definition of right. split loom and flex tubing that I have seen is an eyesore running up the wall and across the ceiling. the only way I can put up with my cables is because I managed to cram it in a fairly flat channeling system that runs up the wall.
next house that I get will have an unfinished basement and I'll have several wiring jacks installed to eliminate this problem.
i am thinking either the z2 or the z3 myself, and for the cables i am going to shelf mounted so running the cables wont be too bad, i am just going to get some flex tubing
yeah, if my room wasn't so larg, I could just run the cables up the rear wall, but my projector is right in the middle of my ceiling.
I assume you have light control?
The Z2/3 projectors put out very little light. Without light control, they are unwatchable during the day on a screen of 80" or larger.
The AE700 also needs light control, but not to the degree of the Z2/Z3. If you put it in Economy mode however you will really need light control as it will be just about the same as the Z2/Z3.
As for running the wire, I concur. If its "not done right" it will not present well to others. I had a 3" conduit run in my wall that I can access from the attic. It runs to my theater room closet, and I have runs for component video, dvi, and svideo (rarely used). My pre processor does Component video switching. So mulitple sources can be connected to the PrePro and only one output to the projector for component sources (prepro takes 3).
i say the best projector for what you need is a sony vpl-es1.. you can come across them for less then $1000 these days
The flex tubing is inside the wall. I had them build it in that way. Along with an electrical outlet in the ceiling. All built into the wall so you can't see it. The flex tubing allows me to pull wires from the stereo location to the ceiling location throught the wall.
awesome. I am going to do something like that in my next place. the previous owners of my current house didn't finish the basement in an easy to work with way.
Thanks for the sugestion, but as i stated my main desire is native 16x9 resolution
You may want to look into the new Optoma H27 projectors that are finally making it to market. They are native 16x9 and have taken some of the trickle down features from the higher end optoma line. It is getting reviewed as better than the H31 it replaced and at a cheaper price point.
it's all subjective as far as PQ goes. It also depends on the screen, source, etc... either of those PJ's would be good for the money. I would go for a widescreen myself, just to reduce scaling and stuff. it presents other problems other than PQ.
spectrumbx said:
If you do enough research you will find that the 4805 is better than the Z2 despite what the numbers say.
QFT. I demo'd both pjs and the 4805 was far better in picture quality despite the resolution difference. The contrast made the biggest difference, IMO.
that's mostly a difference in DLP vs LCD. Contrast can be helped with a grey screen instead of white. I do not have a personal preference between the 2, just offering some info as I have seen it. but I do think that all projector purchases should either be made after a demo or from a place that has a good return policy.
You're right on with that one IDversusEGO. Good luck with your pj shopping Loki008.
yeah, i have been doing some looking into it and am going with a grey screen to help the contrast. I went with the "silverscreen" paint that i have seen recomended a few times arround and as soon as i have the projector and figure out the optimal placement in the room ill get to building the screen
I used silverscreen and liked it. be sure you get the foam roller for a smoother finish. the traditional rollers will put more texture int he finish that might be visible in bright light scenes, like a snowed over field or something.
home depot, like $8 a quart I think. It's just regular wall paint that has yielded decent results. I did a 96" screen with 1 quart of primer and 1 quart of paint.
Counter point...I disagree. I have compared both side by side and the 4805 may have better CR but fails in every other category.
1. It isn't as bright
2. The image is not as sharp
3. You lose resolution. If you ever plan on using this with a PC you WILL instantly notice the difference.
4. The colors are not as rich
5. Does not have lense shift <-- GOD LIKE FEATURE
6. Throw ratio is better for the typical house
7. Better support for new xbox and PS3 resolutions
8. Better zoom on Z2
If you just plan on watching movies...then maybe the 4805 because of contrast. But in all other categories (especialy when gaming and PC's are involved) the Z2 is just a superior soultion.
I'm sorry to sound blunt....but when it is obvious that the parent poster plans on using this a HD experience now and in the future...the 4805 just doesn't cut it. Once you go 1280x720...you can't go back.
-tReP
P.S. I had the 4805 in my basement for a month...along with my Z2 if you need a experience judgement.
1. It isn't as bright - not too important for a dedicated room
2. The image is not as sharp - subjective. I actually leave my PJ a little off focus to reduce the noise in lower quality soruces and lessen the SDE.
3. You lose resolution. If you ever plan on using this with a PC you WILL instantly notice the difference. - I agree here totally
4. The colors are not as rich - the THX standard actually calls for fairly dull colors. I prefer the brighter picture myself though.
5. Does not have lense shift <-- GOD LIKE FEATURE - never used
6. Throw ratio is better for the typical house - very important. less throw is better
7. Better support for new xbox and PS3 resolutions - yep
8. Better zoom on Z2 - I don't use zoom. I have enough room to place the PJ without using zoom, but I would recommend better zoom. in some PJ's zoom can lessen PQ
basically, I agree that the Z2 looks better on paper than a 4805. I would love the higher res upgrade from my x1.
1. Brightness does count even in a dedicated room. When the wife wants to read a magazine or the guys are over for a all night session of smash brothers....you are going to want to have a larger than typical amount of ambient light.
4. Yes...but THX does not cover games or animation typically.
Looking for the superset of needs is how I view his request...not a PJ in a dark room just for movies. If I was just watching movies with a typical DVD player w/o FDDshow,etc I would take a 4805. But the times are a changing....
-tReP
1. I guess I am spoiled by my setup. I have 3 sections of variable indirect light. I can have the rear 1/3 totally lit for poker without really effecting the PJ image.
4. like I said, I prefer the brighter as well.
1. Totally jealous. I had to work with an existing room....
sure, but it is less of a concern. in a dark room, it doesn't take much. I would go with a higher res over higher lumens anyday.
nosoup4you718 said:
i dont care how dark the room is the brighter the projector the better!
Not true if the brighter picture is going to effect CR levels. I would rather have a properly lit screen with great CR than a bright screen with SO SO CR.
It's very easy to have lighting retro'd in even in a fully complete room.
