unhappy_mage
[H]ard|DCer of the Month - October 2005
- Jun 29, 2004
I have an Optoma HD65 that I got last August. Bulbs for it are rated for 3000 hours by the manufacturer. It came with a bulb that lasted for about 1000 over the course of 10 months. I figured, hey, sometimes you get a bad one, the next one will last a lot longer. So I bought a replacement ($330) and put it in. Now this bulb is apparently dead after less than 500 hours of use!
So, is this normal or should I investigate a repair of some sort?
