I don't have a project name for this one yet. I haven't really built or used a desktop in about 2+ year now. My desktop died and work was already a laptop and all I had left was my laptop...so it became my main box along with a docking station and an external monitor. I kind fell out of being interested in building systems was building AK-47's from parts kits and AR-15s..well now I've had my share of those and figured I'd make a nice little file server.
A friend gifted me an Athlon 64 4000+ and an ASUS A8N32-SLI board as well as a modular power supply as he had just upgraded to a new system and had no use for those parts. Since this is just going to be my home fileserver and maybe light gaming (Im a 360 user for the most part) I figured I didn't need to go out and buy an i7 or anything.
The mods on this won't be anything crazy, pretty much either all practical, simple aesthetic changes or indulging my OCD.
I bought a Cooler Master HAF 932 from another user here for a great price so it's going to be the foundation of the mod. I plan on RAID 5-ing four 500gb drives for the storage on this system.
Im also planning on hiding or tidying as many cables as possible which also includes sleeving any cable that's exposed.
So I got home from work last night to a giant box the the other [H] member had sent me as well as some of the internals that I wont need for a little while.
I started working on disassembly of the case right away. So far I have everything removed except for the 5.25 quick release assemblies..it was 12:30 in the morning at this point and I didn't want to do anything in my tiredness that I'd regret.
I was able to sleeve the wires for two of the gigantic fans they include with the case however.
So my current aims for the build are:
I'm also planning on building a little system for my daughter (6) to play webkinz etc on so when I'm stuck working form home she could come hang out with me in my office if she wants to (or gets board playing on the swingset or with legos etc)...she loves Zelda so I'm going to theme it after that for her....got that one ripped down to frame and already started sanding etc...but that will be another worklog.
I'll upload pictures when Im back from the office tonight.
Next on the chopping block:
Sleeving:
Is to figure out all of the PSU wires I'll need and sleeve+shrink them.
Sleeve case cables I'll need
Disassembly cont'd
Remove the 5.25 push button adapters
Drill out the rivets on the case
Painting
Finish taping off the external portion of the case I dont want painted
Sand surfaces destined to be painted
coat of self etching primer
base coat(s)
wet sand
top coat(s)
clear coat(s)
Any suggestions are always welcome, I haven't built a box in so long...now I remember how much fun it can be.
- Paint the inside of the HAF 932
- Sleeve all cables
- A cable management job that doesnt rely on locking everything in with zip ties (i.e. everything easily serviceable)
- Anything else that strikes my fancy along the way
Sleeving:
Disassembly cont'd
Painting
base coat(s)
wet sand
top coat(s)
clear coat(s)
