Project: XBOX Supreme
kier
Hi members,
My name is Richard aka Kier. I've did some nice things in the past with cases
And I wanna share my ideas and skils with you guys. Some previous builds can be seen
on my site madebykier
My first build overhere is not gonna be an pc but an watercooled xbox
Hope you like it!!!
Sponsored by:
Presenting:
Hi fellow modders.
I was looking a long time for this Lian Li case, the PC-XB01
I knew he was EOL, but there is always someone who has this one.
So the search continued.
Did this case is really a beauty and offers quite a few opportunities because
Xbox is not really big and little more content, while the Lian Li is quite large.
It therefore offers opportunities for an expanded water cooling setup to installon the CPU and the GPU Proccesor.
After some research, I accidentally found a lovely Lili with a good friend:
Gnoom172.
Gnoom I owe you one
Also He had a nice Watercooling set for the Xbox. Which is very sweet, but too little for me.
I was then also noted by wwwicked a nice set from the famous Highflow shop ;)
It was the XBOX PRO Dual 40 Watercooling Kit
Also very nice. But for a large case like i have now it’s actually too small
So after some fitting and measuring, I found out that it is quite possible for the following parts:
EK-Multioption RES X2 - 250 Advanced
Laing DDC-1 MCP350 12V
Black Ice GT Stealth 120 Black
Nanoxia DX Series 120MM DX12
Hmm, I think the color combo is gonna be again black / green uv......I like it ;)
And 2 x a EK-Supreme HF Nickel CPU Block
The Supreme's will fit nicely. I just need to mod the brackets, but this will definitely be nice
With this beautiful List I went to Freddy, and Highflow is again prepared sponsor this build
Freddy / Highflow thnx again very much
To start with I have some photo’s taken from the beautiful Lili
These are the victims that I had left from a distant past. ;)
And I could not resist to test the little sweet set
With the set is nothing wrong, but would like some more extreme than this, what will succeed. I know it for sure.
So this is the start of a my new build.
Grtzzz. And to be continued
Update!!!
Today and yesterday got some very nice stuff in of my belgium neighbors and High Flow
Yes, I had some luck ............ Ac Ryan acryl still in there shop;)
Uv green rules ;)
The size of the side panel taken
And put some nice UV strips in the back
Both sides and just the right size
Placed the acryl and lights out
Also placed the sidepanel
And the effect is quiet nice
The other side is coming the same with some adjustments, transparent window and hole in the side panel.
And today got some nice stuff from Highflow
The Black Ice GT Stealth 120 Black radiator
A nice EK acryl top for the Laing DDC-1 MCP350
And the MCP350 pump
And my favorite fan, the Nanoxia DX 120MM DX12
Also not to forget, the 2 EK-Supreme HF Nickel CPU Blocks
Placed the EK acryl top
And this is what's coming in xbox
After all this picture taking, it's time to Dremel the bracket
marked the pieces
After some filing and grinding
And put it together again
Number 1
Both Supreme's side by side
That's it for now. Weekend is coming more ;)
Grtzzz.
Update!!!
I found out that the radiator does not quite fit nicely. When i put him on the inside and place the fan on top it came too much into the case. So I moved him to the outside. First marked the holes for the fittings.
After drilling the holes placed the radiator
Placed BP Fittings
And placed the fan
Power on
I love the looks of the Nanoxia uv green
The total is still quite nice, the radiator is pretty slim. But not finished, something beautiful is coming my way from Mnpc , but that’s classified
I also have painted the mounting hardware for the dvd and hdd black
And I’ve started to work an the other side. In this I want the uv green edge back again. So again sawn another piece of green
And then mod the original panel
The intention is that there is a window in the same shape as the original
Tape on both sides .....
Draw some lines
And after some cutting and filing:
Tape off and he's done.
Now it is obviously not good to have a green window. Windows should be transparent, no color allowed. Therefore I used the green plate and did some more cutting
First, mark and drill holes in the corners for the jigsaw
And again some sawing
First I placed and fixed with bolts to put everything in place
After that I had a mold for the transparent acryl.
And the result
And put everything in place. All that work for a green edge, lol
But I like it
And the window just transparent
Total shot...........you like?
Next update, I’m gonna let you see the loop of the water cooling ;)
See you then, I hope
Grtzzz.
Looks cool, but seems kinda silly that those parts are worth more than the XBox itself. But I guess when you have sponsors giving you stuff it's worth it.
having seen your previous creations, this will be amazing when it's completed :cool:
Thnx, It sometimes happens with watercooling that it is more expensive then the hardware. This is one of the projects where that happens. But it's about the modding not the hardware
Thank you Bill !!!
Have you had issues with your wireless signal droping out and being weak with that case? I've had one for a few years and it's really awful. I just run mine with the top off. I guess the plexi should help with that.
Update 30-05
Here we go again....update time
Had the tray of the Xbox board disassembled and painted it black
This is better than the aluminum look.
Exchanged the original rivets for black ones
scotch tape on it from damage the paint
Nice flat and black
Also did some brainstorming for the window and got some nice ideas presented. I am going to try engraving this time.
So after some practice and see some movies
[YOUTUBE]wSguz5c56Zc[/YOUTUBE]
For the lines I use a diamond point bit
And for coloring / Shadow effect I used a diamond tip
First some practice on a scrap piece and then ............. the real work
with a steady hand you'll do quite well. The first angle
In the dark, and an LED strip behind
And yesterday, the second part done. Pretty funny this engraving ;)
And that was the update for now......you like it? I know I did
Grtzzz.
Update 02-06
Today did the final touches to the engraving. Like this engraving thing
we gonna do this often ;)
The black painted parts are also placed back
And I was brainstorming for the watercooled components. Pump and the 250mm Reservoir
The EK Supreme's with BP fittings
Reservoir next to it
We fill under the xbox drive. This gonna make a plate with a hole for reinforcement
He goes from the pump in to the first block
And from the second block he goes into the radiator, and from the radiator back to the reservoir.
And two last pictures of the hardware with window
This is it!!!
Grtzzz.
I guess you wont get red ringed now :p Nice work, keep it up
Lol. Don't jinx him, It looks far better than anything I have or can do, Even so I will continue to bitch about not having a sponsor.
Update 04-06
Just a hardware update. Yesterday I received from a friend (thanks Marco) a second-generation Xbox, with a Falcon Xenon GPU on board.
The layout of the PCB is also some different and better looking, it is much cooler and therefore less likely to give the RROD.
Old PCB:
further in the update photo's of the new print
On the this new board are placed some capacitors, where some data is printed on
To have a nice clean print I get the caps cleaned with acetone and after some brushing the become quite clean
I've also been busy with the tubes. From pump to the first EK Supreme
And from the first to the second block by BP rotery and multi-link adapter + Custom acryl tube
And from the second block to the black ice 120mm radiator with Tygon R3603 tubing
First part is finished.
From the output of the radiator to the reservoir
And the loop is ready for use
As you can see the new print varies somewhat with the old, and is much cleaner.
Have a nice weekend!!!
Grtzzz.
I'm not a fan of external rads to be honest, but apart from that i think it looks great :)
Update 05-06
I am on a roll with this project ;) A few things to do like:
A paintjob of the DVD player
Disassembled xplayer
And after some layers, a black box. On the DVD there was a clear round sticker. Placed a white sticker in the middle of it
I want to place the reservoir without the holders, so I have a made a piece of mesh
Painted it black an made a hole in it
Placed like this
Put everything together
And the picture of the mesh with the hole for the fill port
The fillport under the DVD, which is holding the reservoir in place
And then ....... the best job, filling. The well-known Feser One UV Acid Green
Tasty poison green
Cheers!!!
And fill it. First a little bit for the leaktest
And after some hours the rest
After some rinsing and waiting Feser becomes quite "calm"
There's still a lot of air in it, but will disappear eventually
Front also quite nice. Reservoir is good to see through the mesh
And another picture of the tribal panel
There are some nice things that i’m gonna do with the radiator and a double bottom for the cables, so he's not finished yet ;)
Grtzzz.
He you guys, wanna show you the 3 generations of the Xbox360 ;)
Click Image To Case Mod Store
We all love to receive packets, yesterday was that day to receive a great package from the US
It was my sponsorship delivery from Mnpctech
The contents of the package and what I'm gonna use in this build
Mnpctech Pro-Line Billet Fan Grills
This is for the back of the radiator, have some nice ideas for it
3M Di-Noc CARBON FIBER FILM
This i'm gonna use for a extra bottom with Uv green acryl
4 BILLET MACHINED ALUMINUM "MICRO" CASE FEET
Gonna mod these case feet also
3M Scotch Clear Mounting Tape #4010
Dremel / Rotary 1.5" cutting discs
Smith & Wesson "Elite" Safety Glasses
Love these glasses !!!
Mnpctech Color Wall Poster
And the famous Mnpctech poster
Bill and Mnpctech, thanks you guys
Next update is about modding some of these products, so to be continued
Grtz.
Update 11-06
Did some brainstorming with the products fromMnpctech
First I have did same nice things with the Mnpctech Pro-Line Billet Fan Grills
Taken some measurements and sawn the acrylic and leave it longer on both sides
And bend it (with heatgun)
Then I taped off the two sides and painted it black
Fitting the Fan grill
And see how it is
Nice .... but not finished, so cut another piece of acryl
Cut out the USB, Ethernet, power and HDMI.I didn't cut out the "normal" TV connection
And Of course place it back again
Nice .... but still not finished. Cut a black aluminum plate
Tape off
And place it back
Yes...... now he's finished ;)
Did the upper and lower edges with my dremel, Just a little polishing
That's it, in terms of the fan grill, more customization of products coming up.
Grtzzz.
And another update!!!
Did some last things to Mnpc products, such as the 4 BILLET MACHINED ALUMINUM "MICRO" CASE FEET
For this round I have cut four plates
Filed and + polished
Placed and It’s nice in the trend of the black and UV green
And I did some nice things with the 3M Di-Noc CARBON FIBER FILM
The idea is to make a double bottom for the wiring of the pump, fan and lighting. I cut out a piece of acrylic and engraved the Xbox logo
And made two carriers, drilled holes and countersunk them also tapped M3
And put it all together
[ame="http://www.youtube.com/watch?v=mFdG0pUk5Ek&feature=player_embedded"]Carbon Fiber Film[/ame]
And the result
Made some total shots
And another picture of the case feet and the double bottom. Green UV Lines run quite nicely I think
Going pretty fast with this build. Next update will show the final pictures
Grtzzz.
I love it all, except the carbon film. I think if you did the same black aluminum panel over the green acrylic like you have in the rest of the project, it would look awesome. But, that is just my opinion. Great work!
Final pictures 13-06
This is it, build is finished again ..... unfortunately I must say.
It's nice to mod something different than a PC.
Yesterday I shoot the final pics.So hope you like it!!!
Power on
Special thanks goes to my sponsors
Freddy @ Highflow
Bill @ Mnpctech
Until the next mod ;)
Keep on modding..................grtzzz.
Lol, shall I stress it myself, and post the temps overhere?
Not that I don't trust you ;)
Im betting it is a huge improvment, Stock Xbox cooling make my any small room hot.
This is a work of art! Great use of the carbon fiber sticker. I covered my CR-48 with it since it originally has a rubberized coating which peels off over time.
Great looking mod, lets hope microsoft have you design the case for the next generation xbox rather than whatever muppet did the last one.
