TANKORR said:edit: Here is the pic I was talking about.
Hmmm, case looks familiar. Thought people would have forgotten about this work many moons ago.
Never did finish it as it was a sort of proof of concept for the side intakes, thematic design, and the rivets.
The rivets you are best to go faux. I used real rivets and some real metal tin sheets. The problem with real rivets is the backside. If you want to place them near the panel edges it presents problems for sliding in and flushing. I had to grind away the back side of the rivets and also fill in the little holes.
Depending on the scale you are going to be using I think the idea of thumbtack heads or using some styrene sheets and punching out circles would work. The styrene however would have a square cut and not curved dome like appearance.
Good luck with the air intakes.
c³
