project- War-Hardened
ReckNball
whats up all this is a new mod i just starting its build is for the new Battlefield 3 game . well let get started .
To start i'm going to use the Cooler Master storm scout case
Products going in to this build are ..
Cooler Master
Storm Scout case
600w silent pro
2x 120mm fans and 3 140mm fans
ASUS
1155 P67 Sabertooth motherboard
EVGA
GTX 560 ti
Phobya
G-Changer 120x2
Phobya Balancer 250 Silver Nickel
Heatkiller
GTX 560 Hole Edition
Koolance
Nozzle Single, G 1/4" Compression [ID: 13mm (1/2"); OD: 19mm (3/4")]
Nozzle Single, G1/4 Swivel Angled [13mm, 1/2"] - Single Fitting
ok it was time to cut ad flip the motherboard tray and back .
new side with clear plex. in it .
ok some .45 holes and no cops showed up to the house lol .
thx all . here r somemore pics of this build the front of the case is being changed . it will now be cut a hold 2 140mm fans or 3 120mm . plus i have an ammo box to cut and install the HD's in to. more pics to come .
just testing this out ordering new tubes . i all so have red flashing lights to give it a muzzle flash look.
Well done! However, something about the weathering on the logo bothers me a little bit. Maybe it's too uniform?
looks like the side of a vehicle that is driving through heavy brush on a regular basis
thats the kind of scratching that results more or less
just my thoughts. not bad so far, cant wait to see more
I probably woulda done away with allot of the stock fan grills my self
I like the idea for the front bezel, but it looks a little unfinished. Maybe fill in the gaps with body filler and bevel the edges? Mesh?
looks really good, great job. the res cover looks like a semi-trucks exhaust though, lol.
