[Project] TT Green-Reactor
Dacy
Hi People :)
-- SwifTech Apogee GTZ
-- XSPC Dual 750 Bay
-- Black Ice GTS-Lite 240
-- SwifTech 3/8
-- Revoltec Dark Green 120
-- Feser One Acid Green
Looks sweet! I liked it better with the green fans though, now it is more of a blue reactor, lol. Is there any significance in having such a huge resevoir?
i generally prefer green over blue lighting, and i usually don't like green and blue together at all. but i like your color scheme in the 2nd picture. it creates a more unified look throughout the case as a whole, and blue looks better than green with the silver/gunmetal case anyway. the green WC tubing adds a nice touch and helps break the monotony of all blue.
may i ask what those white things are in the middle of your water lines? just connectors, or temp/flow gagues?
Yes, but what is it called? Product name?
AXP Dock Station External USB+ESATA
I agree 100% :)
They are quick-disconnect shutoff valve, the quick-disconnect nozzles will separate Liquid on both sides.
More easily to work with the WaterCooling system and add or remove something one the system :)
Do the quick-disconnect disrupt the flow of your overall WC system in any way? If not then that a really good idea that I might have to try myself.
i didn't notice nothing strange on the flow of the WC before and after the instalation of quick-disconnect conectors.
I'm very happy with the results. :)
