Chrome, damn.. Didn't think of that
lol i bought that same toaster... its a peice of shit though.. but it was only 6 bucks lol
It seems to have 2 settings. Warm, or Burnt to a Crisp
I cleared it with some Hightemp resistant stuff. I've never used it. It's not shiny.But the paint doesn't melt so it works for me.
under body led's!!!!!!!!!!!!!
Ockie said:Personally I'd be very worried about the paint... you know the whole fire thing... then agian... what else would you expect from a $6 toaster.
Well since you are into the whole modding thing and don't want to use a resistor... just see if you can find like preforated metal plates to insert... so your toast is shielded... should still get a sufficient toast.
ha ha. as cool as that is, i thought you were gonna break out with a nano-itx board or something and make a computer out of it. i think optical drives in the bread slots would have been cool![]()
