ajampaniki
- Nov 6, 2005
Looks great man. I've been wanting to make something in the style for a whyle now. Just love the way the old mic's look.
uzor said:Once this is done, how do you intend on mounting or displaying this? Maybe build an oversized version of one of those tabletop mic stands like Letterman has on his desk?
Legion© said:What hardware are you putting into this thing? The comparison pic with the soda can makes it look like even a mini-itx would struggle to fit.
Ice_Frog said:Very nice - but there is not a lot space for air and wood isn ´t realy heat conductive - inside will be as hot as in hell.
OK. I'll take this lull in the action to discuss cases made out of wood. The most common comment I get is..."it's a bad choice of materials. The computer will overheat."
No offense to all the junior and wannabee engineers out there but...that's so stupid it's almost funny.
Gather 'round boys and girls and let Uncle Jeff tell you about convection versus conduction. In the world of heat transfer, conduction is the transfer of heat from one solid to another. Convection is the transfer of heat from a solid to a fluid.
Heat generated by a computer's CPU is first transferred to the heatsink by conduction. The material of the processor is physically attached to the material of the heatsink. Heat flows from the hotter material to the cooler stuff.
Next, the heatsink material transfers its heat to the air surrounding it, which is a fluid. Yes, air is a fluid. This transfer is done by convection. Since a fan is involved it is more accurately called "forced convection".
This heated air is expelled from the case by other fans moving the fluid around.
Water-cooling isn't much different. Different type of fluid of course.
Notice that the material used for the computer enclosure has no role in this story.
True, you could argue that hot air trapped in the enclosure gets transferred out by contact with the case material but this amount of transfer is so small compared to the amount involved in expelling the air that it is almost irrelevant.
Case manufacturers who tell you that aluminum cases allow your computer to run cooler are...full of shit. Also known as marketing.
There are exceptions, of course. People making quiet, fanless systems attempt to create a direct path (conduction) from the CPU to the case material. This turns the case into a giant heatsink.
Wood has superior sound deadening qualities and is much easier to work with than metals.
Putting sensitive electronic equipment into wooden enclosures is nothing new. The most famous being the console radios from the 1930's and console TV's from the 70's.
Back to work.
Qtip42 said:Nice work. Sticky.
I haven't read the entire thread yet but are you going to make the shell separate from the hardware inside (like a box inside and the wood acting as a shell)? Would make access easier.
slipperyskip said:Sometime during the process I decided that the bottom cap looked better than the top. I turned the piece upside down and declared it the new top. God-like power.
the black knight always triumphs!rogue_jedi said:
awesome craftsmanship. great concept for a case, too...
