Project: The Midget Rig (another x-qpack mod)
Day 1:
i have seen votey's qpack mod and his work inspired me. just like votey, i hate to give up my dfi nf4 ultra-d. this rig will almost be similiar to votey's qpack. but what's different is that i want to be able to use two harddrives on my hd rack. according to votey's modded qpack, a portion of the hd rack needs to be cut in order for the video card to fit nicely. my plan is to reverse the mobo tray so the I/O faceplate faces to the right of the case. as i visualize this, it seems it would be much easier if done this way.
i plan to cut the support beam below the hd rack in order to fit my video card. also with a little bit trimming of the support beam and the mobo tray, i can make it rest on the metal part above the I/O plate. this way the hdd rack will have something to hold on to.
i will be using a zalman 7700cu to cool my cpu so height clearance is not a problem.
Day 2:
getting the motherboard to fit was alot easier than i thought!
i am looking to buy the enermax liberty 500w psu. smaller than the ocz and its modular for less cabling.
Day 3:
not much done today cause i had errands to do. changed pci brackets and added rear window.
Cool, another X-Qpac mod, only this time the ports are on the other side of the case.
I rather like these mods, I have a mATX board in the X-Qpac and it feels HUGE, slapping a full-sized ATX board is a better use of this case.
Reko, when you change the PSU, take some pix of the case without a PSU so we can see better how the mobo fits in there, thanks!
The Powerstream is a bitch to hide the cables isn't it? Even in my Chieftec Matrix (Dragon with a different bezel) it's hard to hide them all...
here you go.
lol yea big time.
Day 4:
i/o port and pci bracket revision. taken from a full tower case and it fits nicely. i bolted it down to the chassis. now the chassis feels stiff and strong!
^i plan on adding 80mm fan in the front so my cpu will get all the cooling it needs!
Day 5:
I cut out holes on the right side of the case cover for access to the i/o and the brackets.
Zalman 7700cu heatsink came today. Unfortunately it's not stable at 3ghz. Load temp is hitting 50+ celsius and thats without the case cover. I'm guessing the zalman is getting some heat from the hard drives. i will have to create a duct from the front to the cpu..
Keep 'em coming.
Hope air conditioning at the dorms would help the temps. Oh, and winter.
rekojenasni_787 said:
Day 5:
that plastic on the plexiglass? it looks kinda weird :p
stryker, mind my asking where you are this year? :D
2nd floor of bell for me
Mr. Stryker said:
Keep 'em coming.
thanks.
its to keep the plexi scratch free!
UPDATE: 3ghz @ 1.46v stable! Now i need to figure out the air circulation to bring my temps down.
Another update... typical blonde moment: :eek: the zalman fan was using the 5v line for quietness. now it is using the 12v line for full speed! load temp: 48-49c avg. not too bad.
Yes... YES!!!
Excellent work. :cool:
I think once you get the case cover put on, your temps will go down; that thing will be like a wind tunnel.
Votey said:
Yes... YES!!!
hahaha wind tunnel... i sure hope the temps will go down! the enermax liberty psu will arrive here monday or tuesday.
Final Day:
the psu arrived! cable management is a difficult task in this one! one of these day i will have to shorten the length of the wires.
The Midget Rig Specifications:
Enermax Liberty 500w
DFI Lan Party NF4 Ultra-D
AMD Opteron 146 - 3.0ghz @ 1.46v w/ Zalman 7700cu
G.Skill 2x1gb DDR500
eVGA 7800GT 256mb w/ Zalman vf700
SB Audigy 2 ZS
250gb WD 2500KS
300gb Maxtor MaxLine III
Samsung DVD Writer
Idle:
Load:
