Ive only been finished Moondust a couple of months and already Ive got the itchy jigsaw fingers again...
Ive had a 64bit rig in the pipeline for a while now; I only got the motivation to start work recently when I received my Custom PC prizes for being featured in the magazine. The prizes included a case, PSU and various Intel hardware which will be used/ sold to fund the project.
The original plans included a Lian-Li PC-71 however when I received the prizes I had a change of heart. The Enermax case was much better than I expected the build quality is great and the case has some lovely details.
Hmmm, whats in the box?
Here she is
First impressions are good it sports a stylish front bezel which has nicely crafted mesh bay covers and is surrounded by loads of brushed aluminium which will polish up a treat. It also has a blue backlit LCD at the top which monitors the case temperature, fan speeds etc.
Its slightly let down by the splatter paint finish but Im sure that can be sorted out due course. The case was supplied with a meshed side panel, Ive contacted Enermax and theyve agreed to exchange it for a solid one to accompany my tribal designs.
The lockable front panel swings open to reveal the 120mm intake and the drive bays.
Inside the case has much less room than I first thought. You can also see Enermaxs patented wind tunnel which is imo pointless needless to say it wont be staying.
The case also has a 120mm blowhole at the rear.
The front of the case has a pretty sweet aluminium cover on the variable resistor which controls the speed of 4 fans in the case.
The Enermax logo another nice detail.
Ok enough blabbering about the case, time to start work. First job was to make some space to accommodate a BIX3 in the case; the first plan was to mount it to the top panel but with the PSU installed there was a serious lack of space towards the top of case.
Instead; the HDD cage was drilled out which freed of space along the centre brace you can see whats coming now cant you?
Heres a test fit with the radiator near as damn perfect!
From another angle. With the fans installed Ill most likely loose the first two drive bays which may or may not pose a problem, well have to wait and see.
Here she is
