I also have to ask how are you going about finding sponsors for a project like this, I would love to start modding to this extent but just don't have the cash to do this all on my own, I have some great ideas but no funding to proceed.
I must say this is going to look great when its done!
wow, doing arealyl great hob here, thats gonna look fantastic...
What are you using for you 3D Renders? AutoCAD or Visio?
looks like sketchup?
Now you also may have noticed that there are radiators in the very front of the case... how are they going to get ventilation?
This is how:
Two slits on the bottom front of the case.
Comments/suggestions/critique are very much appreciated! Let me know what you think!
~Parker
i dont see how the front rads will get enough air from those slits. you might wanna consider opening it up a bit more in front, or else adding similar slits on the sides and top of the front fascia as well at the very least. i didnt read your whole thread sorry, but make sure you have enough intakes and enough outtakes to somewhat balance each other. it might be easier to make the fans in front blow out through those little slits than try to suck air in through them. just some suggestions.![]()
haha. nice work. but you're previously stated "lan box" will not be all that great for lan parties anymore... its slightly large. looks like the party is going to have to be at your house now... and judging by the sounds of how your dad is... thats the place I'd want it.
Sweet project!
Suggestion: You should get some vents on the side of the "door" as well, I don't think there is enough space for the air to pass through, especially if there are two 2x120 rads![]()
Will do!
I cleaned out the garage a bit, which means I've got more workspace
So expect an update very soon here.![]()
just saw your fs thread, and remembered this build log. what happened to this? "very soon" does not equal "a month and a half."![]()
