1337m0dd3r
- Jun 26, 2002
this is rocking! I love it awesome job so far.
fusionrx said:Nice mod. Does it make the Tardis 'Sound' when it is on? You know the one that it makes as it gets ready to shift through time?
ViriiGuy said:Looks great, but for the championships I would split the removable panel and hinge it.
The removeable panel just cheapens the effect for me. But hinged like doors would really complete the whole look.
ViriiGuy
eendje001 said:I've thought about making hinged doors in there, though i always refrained of doing by the very decent chance it would ruin the front door on the first attempt. So to make hinged doors it there it would require building a new front for the case, which is something, up to now, just didn't have had the time to do.
There are still a few important design issues which block the idea from being practical atm, but at least you made me consider it again, so there's a chance i just might go for it...
webbee said:This is a great mod! Congratulations on finishing such a cool mod! Craftsmanship is great, just a perfect job.
I think you could use a piano hinge, available at Home Depot as well as a ton of other places.They are cut to length, so buy it longer and cut to fit. It might also require you to cut the hinge edge on the door panel to clearence the hinge. There are also invisable inside mounting hinges that would work too. You should talk to someone who is familier with them, so that you could find the right one. I know it's kinda a mute point, but it would make opening the front to show the innerds off easier.
bgates2b said:I really like the looks of that case. I have that same board and I was going to try an put it in an old IBM netvista case (yes, it fits it is that small).
What OS are you running on that board? I am running ubuntu on mine because I could not get XP/2K to load up on the SATA drive even with the drivers.
