cornelious0_0
- Apr 6, 2003
DirtMerchant said:More to come tommorow!.
Good stuff, I haven't seen a creative or well done spiderman mod in quite awhile.....you better not dissapoint.
DirtMerchant said:I think it would be really cool if I could have the eyes go from blue (when HD activity occurs) to white (when idle) if that is even possible. Making that happen would probably be a pain in the arse, but who knows. I'm sure someone knows the proper way to get it to work.
starhawk said:i know how to do it (i think)... you will want to use a flip-flop ic for what you are talking about.
be back in a minute or 30 with the ic # you want from radio shack.
starhawk said:that was fast...
74hct273 is the flip-flop chip you want. this thing is the electronic equivilent of your basic spdt toggle switch. it flips to a channel when its input changes, then flops back to the first channel it was on when its input changes again.
thing is that this baby runs on 9vdc (as i recall...) so it's gonna be real fun piecing together a psu for this thing off of the 12v leads of a molex connector.
if i knew the pinouts for this thing then i could scribble up a circuit for you in ms paint... but that's on the back of the package and it's not onlineso no help there.
starhawk said:like i said... get me a diagram of what pin does what and i will get you a schematic.
it'll be in ms paint tho so it won't look too good
but hey... it'll do the job.
Ozone77 said:You could have white LEDs connected to the power on to light up the eyes (maybe medum-intensity leds) Then connect high-intensity blue LEDs to the HDD activity. Thus, when the HDD is active, the blue would drown the white (higher intensity). I think it is a simple solution that is worth exploring.
Ozone77 said:A more complex solution would be finding 2-way LEDs. These leds have more than 2 legs so they change colors depending on the circuit that is active (like the light on many CD-burners out there) the challenge would be to find one that is blue-white.
cornelious0_0 said:I thought that's what I just said.....![]()
Xtreme^ said:http://www.ebuyer.com/customer/prod...2hvd19wcm9kdWN0X292ZXJ2aWV3&product_uid=72997
Interesting case.......it pulls off the theme well enough that I don't even think it looks THAT bad. Well, not for a pre-mod anyways.![]()
