Project "Spare Parts" Worklog
This is my first "major" mod that I have done and as the name suggests.. this case and all it's parts come from the "spare" parts I have lying around all throughout my closet and storage space.
Here are a few pics to give you a bit of an idea of what I am talking about
This mod will be watercooled, and as I haven't done air cooling for ~6years, you can imagine the kinds of odd items I have laying around in those (and more) boxes!!
To start things off.. here are some pictures of the case I will be using
In the last picture you can see the top of the case where there is a handle with a pop-up top that has a usb connection, small (&LOUD) 60mm fan etc... which will all be removed.
"For What" you ask.. well I will tell you.
For an EXTERNAL RADIATOR ENCLOSURE!!!!!!!
Here is a quick sketch-up of the dimensions
This will fit a 2Fresh dual 120mm Radiator.. BUT before any of you decide to go and make one yourself, learn from my experience.. make the length a TAD bit longer as once I put the pop-rivets in it was an extremely tight fit!
I will be making this out of 26Gauge steel and using only hand tools like my fathers' trusty metal snips, hammer, wood braces, clamps and TONS of elbow grease!
Here is everything all marked up and ready to go
And here it is all cut out
Next was to mark where the 2 120mm fans will go
This is how I decided to mark where the screw holes will go. Lay a 120mm fan down, place the nail in and hammer through. Then, place a 4.5" holesaw in place to trace around
Next I needed to make small cuts where the bends will be... so I bust out the tried'n'true metal snips (been thru allot of projects over the years) and snip'snip
Now... my hole saw is a bit worse for wear, and needed to be sharpened before I could use it reliably, so I decided to break out the cheap'o tin snips.
They work, but don't make very pretty cuts.
Next is a little clean up and then the holes are drilled.
Now for the REAL fun.... bending the metal.
NOTE: The most important thing you can do is make sure you have properly cut (to size) wood with VERY straight edges and a nice workbench which ALSO has a nice straight edge which you can then clamp down your metal in-between
Like so........
Then you take another good & sturdy piece of wood and a mallet to start making the bends.
Remember what I said about having a properly cut (TO SIZE) piece of wood.... a picture and words and something about a thousand
Rinse'n'repeat until you get this
Then another properly sized piece of scrap wood to get the edges straight and holes drilled
A little double sided sticky tape to help hold things together and make a more air-tight seal
Rivets are FUN kids!!!!
Now, time to bend the flaps so this deal can be mounted on top of the case!!!
Short ends....
Long ends...
Basic end result.. needs tidying up!!
Another thing you all should realize before you make one of your own.. see how the small sides have the flap bent in?
Well, that made it IMPOSSIBLE to put the rad into it since all measurements were so tight (didn't have the rad available when I made this.. just went off of measurements..... lol ) so I eventually had to cut those inner flaps off.
Now some money shots!!
Now, I will put together the pictures of mounting the external rad enclosure onto the case then add to this thread.
Hope you have enjoyed my work so far!!
D.
Like so........
Short ends....
Long ends...
D.
