The film has worked out great no problems at all I think the bubble problem is only when you have extreme heat. The lighting used is uv cold cathodeSilent Assasin said:NVM, after a couple more views, I answered my question. But I will still comment on the foam tape, it sounds like a great idea and I might be using it myself.
Another question popped in my head. How well did the reflective stuff work out? You mentioned something about how they claim it bubbles.... Has done that to you yet? Also, with the backlighting, does it have to be white light or would you be able to use a regular cold cathode?
Anyways, the finished product looks great!
That be the intake in the bottom.Elysian said:sick case, but just 1 thing i don't understand... hot air rises, yet your exhaust vent is in the bottom of the case? why did you decide to go with this instead of go with the flow?
