Project „SL5T“
"SL" as you already know from Mercedes Benz, is to make the first impression what this project stands for. Elegance, luxury and simple forms.
The MasterCase Maker 5T is used.
The interior is as discreetly as possible cleared of all unnecessary elements.
The walls are clad with Plexiglas and multi-layered in the design of the mainboard.
An elaborate water cooling system is installed which, however, is kept as minimal as possible.
A cover is made for the cable area, which provides a window for the PSU and on which the ASROCK logo is placed in case size.
The logo is framed with the design of the X99 Gaming I7 as well as I would like the elements of the mainboard to continue the whole case. (The red racing arrows between the lower two PCIe slots)
All cables are sleevedin the hardware colors.
From the outside the contours of the Maker 5T are emphasized by Plexiglas, where also sponsor logos will be found.
So much for the formal part.
The Maker5t will be my next Rig, since I have not yet a good portable Gaming PC.
So I have now also evasive possibilities when my table times problems and above all I can finally also times my table new hardware miss.
Actually, I wanted in this project not so much effort to operate but again will grow the mod again tremendous.
Since I now the first time on a separate X99 board change, I dedicate this mod to the
ASROCK X99 Gaming I7
And let the whole project be inspired by the mainboard.
Hardware
CPU: Intel Core I7 6850K
Mainboard: Asrock Fatal1ty X99 Professional Gaming I7
Ram:
SSD:
GPU: Nvidea Geforce GTX970
PSU:MasterWatt Maker 1200
Case:MasterCase Maker5t
Ram:
SSD:
Watercooling
Bitspower NGTX970MGV2 Acrylic (Clear) BP-WBVGNGTX970MGV2NPAC
Bitspower Leviathan Xtreme 240 4xG1/4" Radiator BP-NLX240-F4PB
Bitspower Leviathan Slim 280 4xG1/4" Radiator BP-NLS280-F4PB
Bitspower DDC Plus Pump BP-DDCPLS
Bitspower DDC TOP Water Tank Integrated Kit 300 (POM Version With Z-CAP II) BP-DDCTOPWTIK300PC3-BKCL
Z-Tube 250( ICE Red) BP-WTZACT250-IRD
Bitspower DDC Pump Cooler Bracket (Red) BP-DDCPCBT-RD
Bitspower Pump Cooler For DDC/MCP355 (Red) BP-DDCPC-RD
Bitspower CPU Block Summit EF (Intel) (Acrylic Top Version) BP-WBCPUIAC-CUMBKWH
Bitspower CPU Block Plate For Intel CPU (Deep Red) BP-CPUIPT-DRD
Bitspower G1/4" Deluxe White Enhance Multi-Link For OD 12MM BP-DWEML
Bitspower G1/4" Deep Blood Red Enhance Multi-Link For OD 12MM BP-DBREML
Bitspower Deep Blood Red Enhance Rotary G1/4" 90-Degree Multi-Link Adapter BP-DBRE90RML
Bitspower Deep Blood Red Enhance 90-Degree Dual Multi-Link Adapter BP-DBRE90DML
Bitspower Deluxe White Enhance Rotary G1/4" 90-Degree Multi-Link Adapter BP-DWE90RML
Bitspower Deluxe White Enhance 90-Degree Dual Multi-Link Adapter BP-DWE90DML
G1/4" Deluxe White Rotary 90-Degree IG1/4" Extender BP-DW90R
G1/4" Deluxe White Mini Dual G1/4" Extender BP-DWWP-C42
G1/4" Deluxe White Rotary G1/4" Extender BP-DWRG
G1/4" Deluxe White Muti-Transfer Adapter BP-DWWP-C03
G1/4" Deluxe White IG1/4" Extender-15MM BP-DWWP-C60
Deluxe White Mini Valve With Black Handle BP-MVV-DWBK
Deluxe White Q Plus-Block BP-DWFMB
G1/4" Deluxe White Stop Fitting BP-DWWP-C06
Bitspower None Chamfer Brass Hard Tubing OD12MM Deep Red - Length 300 MM BP-NCBHT12DRD-L300
G1/4" Deluxe White Aqua-Pipe I BP-DWWP-C17
G1/4" Deep Blood Red CaseTop Water-Fill SET BP-DBRWP-C04
X-Station Mini Power-Extension I Female Version BP-MINIXSP1F-RD
Bitspower Logo Aluminum Thumb Screw For 632 (Deep Red BP-LATSC632-DRD
Bitspower Logo Aluminum Thumb Screw For 632 (White) BP-LATSC632-WH
Bitspower Metal Tubing Cutter BP-CMMTC
Bitspower Flow Indicator BP-FI-CLBKWH
Red Blade For Bitspower Flow Indicator BP-BFI-RD
Control: Aquacomputer Aquaero 6 XT
equipment
Fan:2 x NB eLoop B12-1 ,3 x NB eLoop B14-1
Headphone:MasterPulse
Keyboard:MasterKeys Pro M
equipment
Sketches
In order to bring the project as smoothly as possible, I took this time a bit more time on the computer and already times sketches for the different covers created.
The elements are glued together in several different colors.
Partially varnished, partially foil and partly (only) polished.
For use comes Plexiglas in various colors and thicknesses, aluminum foils and varnishes.
This is only the rough basic idea, should expect again but not look good I let myself think of something else: thumbup:
This cover comes on the right side in the case inside where the drive bays sit.
To the right the original pattern and to the left the lighting effect.
Here the front, whether the red arrows will really work well, we will see
Here the front of the PSU cover, the design on the left will frame the window to the PSU
And here the elements for the Windows, not completely in red but as template it is enough
Hardware pic´s
The majority of all components are already there, but see for yourself:
A big thanks goes to all who support me with this project:
ASROCK
COOLERMASTER
BitsPower
Blacknoise
Avexir
