EnergyTeam
- Sep 11, 2015
The design of this project aims to create a case simple and attractive.
This project will feature several mods such as the front, the interior, the inverted ATX motherboard, top, among others.
The box will be focused for watercolling was not she one TJ07.
Photos of the original case:
Taking out the motherboard tray to be modified and inverted:
Taking out the original rails to be replaced:
I don't like to see the bays in this case so...... OUT! ehehe
Taking out the midplate to modify rails:
Making the new rail!
The new rail (below) and the original (above):
The case with the new upper rail mounted:
The design of the new motherboard backplate (paint rules ehehe)
The idea was to create a backplate more simple (without those horrible air vents) but I didn't wanted to make a case without any airflow, so this design came up!
Starting the new backplate:
I don't like to see this Fan's in the backplate, but as I mentioned earlier I don't want the case without any airflow. So after seeing another project this idea came up.
Modifying the Fan's:
Ater modifying the Fan and some sanding here is the result!
