This is a small project that I decided to start on right after I finished my 'Mithril P4' case mod.
The RFIS is something that allows me to kill time, play around with some design ideas I had and most of all have an insane time with fire crackers!
How RFIS works...
The simplest way to explain RFIS would be:
Simply put, I plan to step-up 12vdc to around 30kV @ around 1 - 2A connected to a spark plug. My initial design was to have 12vdc applied continuously to the coil and then kill the applied voltage resulting in a single 'spark'. I have now decided to pulse the coil with 12vdc @ 2kHz resulting in a continuous spark!
The coil I plan to use will look something like this:
How RFIS works...
