Project: Project
maverikv
New Watercooling build because I realized that if you're going to do something, you do it right. This is going to be my gaming rig. CPU Only Loop for now is the plan:
Build Parts:
Antec 1200 Case
Corsair HX1000W Power Supply
Asus P6T
6GB Mushkin 8-8-7 DDR 2000
Core i7 920 D0
2x Geforce GTX280
GSKill Falcon 128GB
Oh . . . and the monitor is the Samsung 50B850 50" Plasma =)
WC Parts:
Laing Pro w/ XSPC Top
XSPC RX360 Radiator, 6 S-Flex 1200RPM Fans Push/Pull
Heatkiller 3.0 LT
Tygon 1/2" ID
Bitspower Comps
Couple screenies of the parts:
Hardware: (I stripped the stickers off the 280's and they look way nicer)
Monitor =):
Rad with fans:
I'm going to mount it in the front of the case. Just using one DVD-R drive, so the other 11 bays would be empty anyway. This way I don't have any ugly shit sticking out of my case.
More to come . . .
this should probably go in the cases forum under worklogs. idk if you can move it, but a mod can and will. good luck with the build!
Whoops I meant to put this in the water sub-forum. Can a mod move it wherever it needs to go? More updates tonight I got a lot done last night
