I've finally got up enough courage to paint the inside of my case after talking about it for months. Since all my case fans are white LED i decided to paint the inside white to go with it. Here are some pics for starters.
Here are the mother board and hard drive trays primered ( cant remember which coat of primer this was lol)
And here they are on there second coat of white
Heres a little sample to give you an ideo of how its gonna look
I did the 3rd coat of white paint on the mobo and hd trays today and also did the first and second coat of primer on the case the 2nd coat is drying now but here are some pictures of it
and since everything is going to be white i couldnt leave out the case leds and fan controller leds ( it would look real messed up to have everything white and fanbus and case leds blue so i changed em)
hope you like it, i should have the case priming finished today and start on the first caot of paint tomorrow and start on clear coating the trays tomorrow also.
and once ALL this is done i will then start on painting the outside white also hopefully this will be done by next weekend ( doubt it) because my new Neo2 Platinum and 3500 Winchester are coming in this weekend. and if the paint isnt that good its because im only 17 and just got into computers 6 months ago and this is my first ever paint job hope you like it tho
