Finally stripped my old P2 system and had a good look at the case. I can see alot of things happening to it but it will take me a good long while before its finally finished if ever. So I'm in the planning stages at the moment. btw I'm brand new to W/C so I dunno exactly what types of blocks I want just yet but I know the ones I have seen about the place and will be changing as needed
Plan:
Watercooled system:
Reservoir: Aquatube (Aquajet & AquaLED) :hip:
Radiator: 240 sized with 2 x 120mm fans
CPU WaterBlock: Danger Den (plexi looking blocks with LED mods)
Paint case frame and panels :thumb:
The Victim:
as you can see plently of room for the W/C 240 Radiator up front
side panel will be recut, this was my first ever cut with the dremel :duh: , wish i didnt now as I know enough now to do a design cut, may see if I can make a blank panel later on if not etching on plexi instead
perfect place for the dual rad there see
good place for the Aquatube there up top :hip:
completely stripped, only the frame, definate paint job on that
afew cuts on mobo tray for wire management and waterblocks
Plan:
Watercooled system:
The Victim:
