Project MyLi
malicious
Before I get started I'd like to thank my lovely wife who puts up with me spending money and time on my hobby of case modding. :)
About a week ago I saw a Lian Li Rocketfish on Ebay for $63 bucks. What a bargain for a Lian Li full tower! I named her MyLi since it's my first Lian Li case.
I'm borrowing a lot of my mods from excellent Rocktfish projects like ELITE and Dark Desire.
Mod Plan:
Top: custom 4x120mm grill including brushed copper elements
this is to prepare the top for a Quad TFC Xchanger or a GTX480 radiator in the future
Front: removal of stock panels to paint/powder the silver door frame / custom cutouts with brushed copper underlay elements
Interior: black powder coat (perhaps black AND copper colored powder)
Interior: create partition between psu/hdd area and mobo/drive bay section - brushed copper partition
side panel: two cutouts - top cutout will be real glass - bottom cutout will be black acrylic and/or brushed copper
Here's what I've done so far. Excuse the mess, we're painting.:rolleyes:
Disassembly
Bought some new goodies including a rivet tool! ;)
At the recommendation of my wife I bought an organizer for the parts that were flying off!
Bake for 2 minutes at 200F :D
Copper sheet for the partition. Notice the slight factory grain
Starting to brush it with my ghetto fabulous metal brush tool
This is how it turned out - dead sexy
That's a very good deal.
I paid $650 for a 4'x8'x1/8" sheet.
[edit] lol, I wrote 4"x8", I meant 4'x8' ... but when you're spending about $10,000 and over 700hrs on a mod, no details can be spared. ;) [/edit]
I was gonna say.. $650 for a sheet for a $63 case. That brushed copper is nice.
hehe. I seen these rocketfish on ebay cheap too. Nice mod log you got going on.
working out the powder coating
working out the partition placement and brackets
thinking about making some cuts but got some other stuff to do today....
Good to see you've started working on yours, I will be looking forward to results!
thanks ... i'm going to make a little video about how i brushed it so people can do their own
it's not rocket science but i did learn a couple tips so it should be helpful for some....
well i got some decent holes cut for the fans/rad but i ended up slaughtering the fan screw hole placement so i'll have to figure something out about the top... i wish they freakin made a 4x120 radgrill ... why they hell don't they ... i sent kikboxes an email a week ago and no response....
Your best bet is to get a custom piece of smoked black plexiglass... Cut it to the size of what the radgrill *should* be... Mount it on top, then dril a few mounting holes through both it and the top of the case...
Mount it UNDER the holes in the case, and cut your holes through the plexi (since you're drilling through the plexi, use the case holes as a guide)
Then mount it back on top after you're done, since they're now guaranteed to line up properly...
Then take it off, and drill the proper mounting holes right in it, for the radiator... Mount it on top of the case, use those mounting holes as guides for drilling through the case, and mount it all together:
It'll look wicked if you round the edges and polish them... And you can even light it with orange SMD LED's or something to go with the whole copper theme :)
Just a suggestion.
sadly this project is on hold.... I've decided not to build a new rig at this time...
too much other "grown up" stuff going to be playin around in here...
to be continued...
